07 335i coming to life
derekgates
740
375
NW FL
derekgates.us
2011 335is
Gosh that wheel, wing, tint and red color combo look amazing.
MHD short cap? Are you worried about battery drain leaving the dongle plugged in all the time?
Heyfred
61
74
2007 335i
Coils on. Car feels more responsive and exhaust note has a crisp, higher pitch sound. Most likely leaned up some. MHD tune coming next.
Reactions: TheFixer
Heyfred
61
74
2007 335i
MHD Stage 1+ installed . Now, I need a the rain to stop and go for a test drive. Used MHD WIFI adaptor.
Reactions: derekgates
Heyfred
61
74
2007 335i
RB 2s are installed with RB 1.75” inlets, down pipes and Precision RaceWorks coils. Running stock air box with z4 35is lid and K/N filter. Also, has ATM intercooler and upgraded charge pipe. Modified front inlet, using a cut off inlet connection from a stock airbox. Cut 1.5” off RB inlet and then inserted a 2” section of tubing, now, no issues with pulling rubbing inlet.
Reactions: TiAgAu and NoGuru
Heyfred
61
74
2007 335i
Bought a HM style front splitter and was disappointed with the design. So, in typical fashion, I had to re-engineer to make it work. The splitter is hollow and will crack over time. So, had a friend graph in solid composite disc where the fasteners go thru and lay carbon fibre over the repair area. Will replace the setup fasteners with countersunk for the final install. Laser cut a backer that will be inside the bumper cover for the nuts to sit on to help not to deform and tear the bumper cover over time.
Heyfred
61
74
2007 335i
New hardware installed.
Heyfred
61
74
2007 335i
Final fit on the the front splitter. Made backer that fits behind the bumper cover which adds strength and backing to help prevent distortion once the bolts are tightened. It is also riveted in place so it will stay in position if the splitter is unbolted. Upgraded all mounting hardware to stainless steel and to Allen instead of Philips.
Heyfred
61
74
2007 335i
Finally has color. Letting it cure over the weekend and install on Monday.
Heyfred
61
74
2007 335i
Lasted 50ft. Turning the car around in my driveway , lightly brushed the curb and split. My composite person told me it was a poorly made when he was making improvements on it so I could bolt it on. No more splitter.
So, just put SS button head bolts in to fill the holes.
Heyfred
61
74
2007 335i
Amazing how much heat is exiting on the turbo side.
Heyfred
61
74
2007 335i
Louvered hood project is complete.
